Author Topic: Roberts RD60 DAB/FM radio repair with service manual  (Read 8097 times)
Offline rh100605Topic starter
« on: December 04, 2020, 01:27:52 pm »
I recently bought a job lot of DAB radios, the first was a Roberts RIC 1 which only worked when pressure was applied to the side of the Mullard  LP1175 Xtal IF can which had an open circuit primary. I depressed myself by looking inside only to find that the hard glue holding the tri-fillar winding bridged the ferrite and paxolin base. It had cracked. In my opinion irreparable.
The second radio was a Roberts RD60 with the normal covering falling off. It powered up with no sound and the display kept returning to the same point.
Looking on the Vintage Radio site I found a very helpful member who offered a pdf of the service manual. With his approval I have copied the service manual here. It is splt into two files due to the EEV forum  upload limits.
To remove the electronics you have to remove the handle. The ends of the handle have pins that go though the sides of the case and are held by circlips. Push off the circlips , pull out the pins and then remove the threaded inserts in the sides of the case.
I removed the aerial and power inputs from the back and then the speakers leads. Then, with difficulty, removed the electronics. I removed the smaller screening cases over the two switching regulators and found +5 and 3.3 but the 1.2v was at 0.6v. Also the reset line was held at 1.4v.
I removed IC8 - ABLIC S-8550AA-M5T1G and measured the resistance between 1.2v and ground as over 3K so it was worth replacing the chip. The reset chip IC10 - NCP803 2.93V now showed reset at 3.3v so the switching regulator had been pulling that down too (and probably up during reset).
I bought a new regulator from Mouser UK and fitted the sot23-5 package. I used a microscope to do this. The radio then came back to life. Now to recover it.
I have since found RD60 radios with no sound. The device marked 2005 in the screening can ( TPA2005D1-Q1 1.4-W Mono Filter-Free Class-D Audio Power Amplifier) was at fault
« Last Edit: February 06, 2025, 02:15:03 pm by rh100605 »
The following users thanked this post: Greg J, David_AVD, coromonadalix, lucatz
Offline Greg J
  • Hi there
Re: Roberts RD60 DAB/FM radio repair with service manual
« Reply #1 on: February 03, 2025, 11:39:22 am »
Amazing , thank you !
We get these radios at Repair Cafe all the time - and any Roberts radio and schematic for it that I can get - it's always welcome. These are PITA to find faults in, especially those little modules on top.
Take It EV
Offline brainwash
    • Hack Correlation
« Reply #2 on: May 15, 2025, 10:35:48 am »
I have an RD-60 but it seems to be a different revision. The main PCB is completely different, mostly single-sided, with a different naming scheme. For example the original IC5 is now IC1, but still the same flip-flop. This makes debugging quite a bit harder.
Offline brainwash
    • Hack Correlation
« Reply #3 on: May 16, 2025, 09:36:02 am »
Detailed PCB photos part 1
The following users thanked this post: rh100605
Offline brainwash
    • Hack Correlation
« Reply #4 on: May 16, 2025, 09:36:37 am »
Detailed PCB photos part 2
Offline brainwash
    • Hack Correlation
« Reply #5 on: May 16, 2025, 09:37:42 am »
Part 3
