Hi all,
I have the opportunity to buy a Rohde Schwarz CMS50 radio test set from my employer. Before I make the purchase I would like to know if the device is fully functional. I am testing and figuring out all the functions. I’m a bit confused with the following results:
First image:
Connected a 434Mhz antenna to the high power INPUT 1 jack. Creating a RF signal with my remote car key. The device measures -33dBm.
Second image:
Connected a 434Mhz antenna to the low power INPUT 2 jack. Creating a RF signal with my remote car key. The device measures -72dBm.
Why is there a 39dB difference between the channels? Is the input 2 damaged and reading low? Is there a setting that can cause this difference? Or replace user?
Second situation:
INPUT 1 jack is connected to INPUT 2 jack with a 50E coax. Device is operating in tracking mode.
First image: output power: 0dBm
First image: output power: -10dBm
First image: output power: -20dBm
First image: output power: -40dBm
I would expect that the measured power is about the same as the source power. But the measured power is about 55dBm lower. Consistently for the different output power settings.
Why?
Thanks in advance!
Greetings Jasper
Netherlands
