Author Topic: Rohde & Schwarz CMU200 CMU-U99/B99 RF1 level range identical to RF2 option  (Read 2426 times)
Offline hafrseTopic starter
Hello,
I have the "CMU-U99/B99 RF1 level range identical to RF2 option" in my CMU200 but no 2:nd generator (Option CMU-B95/96).
Does the CMU-U99 option reduces the RF1 input to 2 Watts ? normally the RF1 accepts up to 50 Watt  cont.
What I know is that the  only Option CMU-B95/96 (2.nd genrator option) reduces the RF1 to 2 Watts which I do not have in my CMU200, could not found anything about that in the spec sheet (attached)
Thanks
Offline richnormand
I do have the TxAux on mine and there is an applied sticker with Max 2W on the RF1 connector.
I will check again the options when I get access back to my bench (dismantled to make a path to the new furnace before winter).
Repair, Renew, Reuse, Recycle, Rebuild, Reduce, Recover, Repurpose, Restore, Refurbish, Recondition, Renovate
