Hello Everyone,
bought at HamFair a defect Power Supply R&S NGSM 32/10
by inspection, found a defect 7805 Regulator ( PCB heated very black ) N307 on Regulator Board
this is the NetSense Regulator and gives 5V out ( 5VMC ) for the CPU and some drivers, and frontpanel PCB
when replaced, PSU works perfectly in all the functions, but ... the regulator gets very very hot even since the first 10 minutes... so abnormal !! ( hence the Blackspot op PCB )
The input is +/- 12-13V and current is 520mAmps, so dissipation +/- 6-7 Watts..
Can someone check if this is normal ? or should the current be much less..
I checked every load and Display = 250mA - Regulator Board itself = 220mA en IEEE board +/- 50-100mA
If anyone has an idea.. much obliged.
Schematics in annex !
JP
