I just wanted to post this for anyone buying a SMIQ-03B or similar (probably any of the SMIQs). I bought a SMIQ03B with the front glass discoloration due to the metal screen and was able to get a very good deal on a fully equipped SMIQ-03B.
The guys in the forum earlier had mentioned replacing the defective screen with a new glass. I took apart the front of the SMIQ to be able to measure the glass from the inside. the glass was held in with 10 or more screws and a metal frame. Once removed, I noticed that the glass was very thick and appeared to be de-laminating in the middle. The posts indicated that the glass has a metal screen in the middle to preclude emissions. I decided to try to separate the glass parts to see if I could separate the parts. I wasn't worried about breaking the glass, as I could still measure the frame to get a new piece of glass to replace it.
Once I really started probing with a very thin X-acto knife, the parts started to separate and I probably got about 2 square inches of glass separated before the front glass part started to crack and break. I discovered that the front part of the two-part glass was extremely thin (2 mm or so) while the back glass was much thicker (6-8 mm). they are separated by a thin (<1mm) rubber/metal web membrane and glue.
It took a while, but after some time, I managed to fully remove all the front glass and the offending membrane from the rear glass, being very careful to slowly raise the membrane and thin glass from the rear glass.
Since the rear glass was the part in the frame, returning it to it's frame and assembling, gave me a nice clear screen, without the clouding around the edges that I had before.
I had some thoughts about why R&S would bother with a screen in the glass before I took the SMIQ apart, but I found that there is a thick metal panel at the rear of the front section (the controller) and another thinner metal piece between the circuit board and the LCD screen. Thus, the only thing that can radiate from the glass is the LCD. Very strange. Why would they worry about that?
Just thought I would share,
Strick
