Author Topic: Rohde & Schwarz SMIQ03B with Error 110 Output unleveled; IQMOD: ALC failure  (Read 25890 times)
Offline drhex
Probably same process as getting from 02B to 03B - you just need a factory install key. Can probably be reverse engineered somehow. Do you have info on the 6L variants? SOme around for parts on the Bay...
Offline Jarek
Re: Rohde & Schwarz SMIQ03B with Error 110 Output unleveled; IQMOD: ALC failure
« Reply #51 on: November 15, 2023, 01:53:22 pm »
Angielski
I also have a problem with SMIQ03
I have IQ Modulator version A240.1084.98.00.06
This is different than the ones described in the posts.
Here are the transistors marked as( .H1 ) .  There are three of them in series under the radiator. The casing is as in the photo.
What kind of transistor is it? Does anyone have a diagram of this version of IQ Modulator?
Offline drhex
« Reply #52 on: November 16, 2023, 10:50:32 pm »
Schematic I have is for 1084.9800.01S. V102 is in there as SHF-88. Parts list for 1084.9800.01SA shows it as SHF-O186K4230TR made by Stanford
Mine failed after sending it out to calibration. Soldering in another switch didn't resurrect it so bought another modulator and calibrated it myself. Worked reasonably well, +.5dBm off over the whole amplitude and frequency range. Can live with that.
Offline Jarek
« Reply #53 on: November 17, 2023, 01:19:48 am »
Thank you Drhex
You're right, it's SHF0186.
My module gets very hot. I am looking for damaged elements.
Offline drhex
« Reply #54 on: November 17, 2023, 12:22:08 pm »
I have a few more or less broken modulator boards here in case you're interested.
Offline Qw3rtzuiop
« Reply #55 on: November 17, 2023, 12:41:44 pm »
Take a look here:
http://www.ko4bb.com/getsimple/index.php?id=manuals&dir=Rohde_Schwarz/Rohde_Schwarz_SMIQ
Offline Jarek
« Reply #56 on: November 17, 2023, 03:13:08 pm »
Thank you for the offer Drhex.
I've already bought it.
Regards
Offline Jarek
ERROR:
   VECTOR_MOD and LEVEL_ATT calibrations fail with 'Reference voltage oot (6.9 ... 12V)
Which reference voltage exactly is it?
