Author Topic: Successful HP 3101-2046 DPDT Switch Repair!  (Read 5957 times)
Offline ZGoodeTopic starter
  • Grad student by day, equipment nerd also by day
« on: January 31, 2024, 05:00:23 pm »
I had a broken DPDT switch on my HP 4277A LCZ meter that unfortunately I could not find a replacement for on Ebay or Digikey.  There were no comparable/compatible replacements that I could find, particularly since these are nonshorting switches.  Since the only part that was broken was the plastic lever toggle bit, I decided to design and print a replacement toggle using Fusion360 and the SLS printer we have in the lab.  My replacement part was printed using PA12 nylon and then finished to a nice glossy black using a propane torch.  It works great, and feels pretty much identical to the original switch.
Re: Successful HP 3101-2046 DPDT Switch Repair!
« Reply #1 on: January 31, 2024, 05:02:23 pm »
more photos of the repair!
« Reply #2 on: January 31, 2024, 08:43:25 pm »
Can you post the file, in the HP parts thread, so that this can be used by others as well. Nice work on making the new body.
« Reply #3 on: February 01, 2024, 08:53:37 pm »
Yeah, I can do that.  Can you link to that thread?
