Author Topic: Rohde & Schwarz SMU200A Vector Signal Generator repair log  (Read 2139 times)
Offline Qw3rtzuiopTopic starter
« on: January 29, 2019, 05:36:15 pm »
Today i recieved a broken SMU200A. It is the 3 GHz single channel version.
The description was "firmware problems".
After powering up Windows is throwing different errors at the boot process.
I did a BIOS reset but that didn't worked. I decided to replace the dead CMOS battery. After another BIOS reset and a properly adjusted date & time its booting up properly.
The signal generator application threw some errors that disappeared after a self-adjustment.
Unfortunately the keys and the rotary encoder aren't working at all. Just the power button and the LEDs are working.
The instrument can be operated with a USB mouse. External keyboards don't work either.
It seems to be a windows problem. Anybody has experience with these kind of problems?
Things done:
  • cmos battery
  • dust cleaning
  • hdd copy
  • self-adjustment
To do:
  • bring the keyboard back to work
  • more dust cleaning
  • fan replacement
  • hdd->CF-Card replacement?
  • CCFL->LED replacement?
« Last Edit: January 29, 2019, 05:38:22 pm by Qw3rtzuiop »
Re: Rohde & Schwarz SMU200A Vector Signal Generator repair log
« Reply #1 on: January 31, 2019, 11:17:24 am »
It works!
I booted the device into the recovery and did a full system rollback.
After that I installed service pack 3, this system update (https://scdn.rohde-schwarz.com/ur/pws/dl_downloads/dl_firmware/zip_1/SystemUpdate4SignalGenerators.zip)
and then the latest firmware (https://scdn.rohde-schwarz.com/ur/pws/dl_downloads/dl_firmware/exe_1/SMU200A_32028621.exe).
I didn't expect this repair to be that easy especially for the price i paid for this item.
The next thing is a fan replacement. The ones that are built in are very noisy.
« Reply #2 on: February 08, 2019, 10:44:36 pm »
Today i replaced the hdd with an ssd.
I used one of these adapters:
https://www.aliexpress.com/item/44-Pin-M-2-NGFF-SATA-SSD-to-2-5-IDE-SATA-SSD-Converter-SATA-Adapter/32798017224.html?
In total it is cheaper than buying an IDE ssd.
I also did a boot time comparison.
hdd: 2:56
ssd: 1:58
The slowest part is the initializing of the firmware. That isn't any faster with that ssd.
« Last Edit: February 08, 2019, 10:46:16 pm by Qw3rtzuiop »
Offline SilverSolder
« Reply #3 on: February 09, 2019, 12:25:09 am »
Nice project!  -  What does a vector signal generator actually do?  -  I can understand a vector signal analyzer, but a generator sounds interesting.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #4 on: February 09, 2019, 12:34:55 am »
have you made backup or image copy of the original installation? thats the first thing you should do... congratulation on your success.
« Reply #5 on: February 09, 2019, 10:56:19 am »
A vector signal generator is able to transmit complex signals. You can manipulate the magnitude and the phase angle.
This unit even has two baseband generators. But im not sure why i need two of them :o
@Mechatrommer
The hdd backup was the first thing i did.
