Author Topic: ROHDE SML-02 over ERROR  (Read 459 times)
Offline hnjmklTopic starter
« on: April 20, 2022, 07:56:24 pm »
I don't know if this is a problem or defect of my new purchase, setting 13 dBm gives them from 6 MHz up to 2.2GHz, from 5 MHZ-9 KHz, over 11 dBm from over error.
Offline Qw3rtzuiop
Re: ROHDE SML-02 over ERROR
« Reply #1 on: April 21, 2022, 05:22:13 am »
Don't know if I got your fault description right but you can set a higher than specified output level on the device.
The specification is 11dBm max for the SML at frequencies above 5MHz.
If you set a higher level you get a warning message like level over range or something similar
« Reply #2 on: April 21, 2022, 11:58:41 am »
Due to my n inability I was able to locate the 11 dBm limitation in the SML-02 datasheet
