This is a very old drum machine.
It is all working except the programming part, where you write your own rhythms to RAM.
The write to RAM I believe is triggered by an Interrupt, which can be seen on the schematic as pin6 on the top of the 8048 processor, and marked INT.
This Interrrupt signal is present when a Write is asked for, but nothing actually happens.
There is no activity from the (NOT) RD or WR pins 8 & 10 EVER that I can see.
Even at bootup, neither RD or WR show anything at all.
It seems the machine works normally without use of the RD and WR functions, I have lifted these pins from the sockets, and it still goes Bosh, Tish, on it's pre-programmed patterns, it just won't record any custom data.
With these pins lifted, there is still no activity I have managed to spot on these pins from bootup onwards.
So I kind of suspect the processor, but am unsure whether something else might be preventing the RD WR pins activating.
Is it at all likely that a processor might go faulty by losing these two pins?
The 8048 processor has Mask ROM on board, there are programmed substitutes available on the Interweb at significant cost.
I took this punt once before on a different product that also had what I thought was a Mask Rom Processor failure, but lost the bet, so am a little more cautious now.
Full service manual here:
http://www.synthfool.com/docs/Roland/Roland_CR78_Service_Notes_BW_medium.pdfPSEN and ALE are present, by the way.
