I've recently acquired a McAfee FW-325 unit in non-working condition and, upon inspection, I think it is suffering from the well known Intel Atom C2000 bug.
Not wanting to give up on this unit, I am trying to apply the workaround for this bug - i.e. add a pull-up resistor between LPC_CLKOUT0 and the 3.3V supply rail.
Problem is I don't know where on the board LPC_CLKOUT0 goes.
So far, I've tried probing the trace pads near the CPU (mostly those which are unpopulated or with resistors on them), as well as any pin headers or pin header slots (i.e. unpopulated) on the board, in the hopes I can detect a 25 MHz signal (a weak one should still be present, based on Dave's video on the Synology NAS unit which had a similar problem).
But had no luck so far, so I'm starting to think maybe I could locate the signal from LPC_CLKOUT0 starting from the BIOS IC instead (to my limited understanding, the signal from LPC_CLKOUT0 ultimately controls how the CPU accesses the BIOS code from the EEPROM IC).
However, I am treading unknown waters here and I wanted to ask for any advice or indications if my approach makes sense and/or if I could locate LPC_CLKOUT0 somehow else.
Below are pictures with the entire board, the CPU and two ICs, one of which I suspect hold the BIOS code.
Thank you!
