I recently picked up a Roland E-20 for cheap. In great condition, just had to replace 1 tactile switch and now in perfect working condition, however: the LCD screen is rather 'dim'. Only if you look at the lcd screen from a sharp angle, the characters are clearly readable. I could not find a service manual for this synth/keyboard, so not sure if the contrast can be adjusted. There is no knob for this on the device itself. There is a potmeter next to the connector to the lcd board, but I'm not sure if this is connected (could not measure a direct connection from the potmeter to the lcd connector), see attached photo. I do not dare to change the potmeter without knowing for sure what it does.
Does anyone have the service manual available as .pdf? Or know if this potmeter indeed is changing contrast?
Thanks.
