kkkkkkk, I think how did you came to the conclusion of the faulty CPU will be interesting in the repair forum.
Well, I had bridged link D on the board and that was supposed to get the meter to loop through a diagnostics sequence.
However, nothing resembling a sequence was showing on the display, but rather something of a static, undiscernable kind of content (might have been blinking rapidly, but nothing looking like a cycling through a sequence).
I then checked voltages and clock signal and they were both fine.
I believe I have also removed and reseated the CPU and ROM IC's.
I might have done other checks too, but can't remember any others at the moment.
So, at that stage, the CPU IC was one of the potential causes of the behaviour (along with other candidates).
Then, checking on our favourite online auction site, I found a replacement IC that wasn't discouragingly expensive and I thought I can give this theory a try without considerable additional cost.
Once the replacement IC arrived and placed it in the original IC's place, I could immediately see a change in behaviour, more towards what I was expecting the meter to do.
