Author Topic: AC Fan Wiring w/ Pics  (Read 785 times)
Offline vidarrTopic starter
  • Country: br
« on: December 18, 2019, 01:00:26 pm »
This AC I got free came disconnected and I need to reconnect this fan motor to the control board and separate capacitor. It seems no matter which way I would reconnect wires, there is always an extra wire that I don't know where to connect it. The schematic on the side of the motor seems simple enough, but it doesn't match what is actually there. It looks like someone made some type of modification to the wiring too. This should be simple for you guys to help me. I don't want to attempt anything without knowing for sure it is correct, because this 240V.
Thank You!
Offline Andy Watson
Re: AC Fan Wiring w/ Pics
« Reply #1 on: December 18, 2019, 01:22:35 pm »
Yellow wire on motor goes to yellow wire on the capacitor.
Orange wire on motor joins with brown wire from capacitor and then goes to the power connector.
  • Country: br
« Reply #2 on: December 18, 2019, 01:58:04 pm »
Thank you, of course. As soon as mains power is involved, it is like self-preservation kicks in, shuts off my brain, and says ask someone smarter just in case. LOL
Thanks!
