So, I reassembled and still no luck. Does the speed at which you turn matter?
So, if I test the thing and at each detent I have either
1) neither A or B connected to middle
2) A connected to the middle
3) B connected to the middle
4) both connected to the middle
it should be working correctly, no?
Are the connections make before break or should it matter (I am wondering if when I bent the pins back, I bent it too far and the pulse is being thrown off by something making or breaking connection to quickly or a hair late.
I guess I need to understand these better. In theory, you should be able to send a pulse with one detent click, no?
So if I go from no connections between the pins, to A to C but B not connected, that change is a "pulse" that should be
detected by the microprocessor controlling values, no?
Thanks
I am still trying to understand how it creates a pulse, but I will read up on the internet.....
You put a pull up resistor on A and B, ground on the common (usually the middle pin). When you turn the shaft, the contacts short one or both pins to ground. It's essentially the mechanical equivalent of open collector/drain.
