Author Topic: round 45mm photovoltaric ? where ?  (Read 869 times)
Offline oz2cpuTopic starter
    • webx.dk private hobby and diy stuff
« on: November 01, 2022, 09:23:41 am »
i need a 45mm round photovoltaric any one seen that ?
https://youtu.be/wRORiFsNX2U
Radioamateur OZ2CPU, Senior EE at Prevas
EMC RF SMPS SI PCB LAYOUT and all that stuff.
youtube : oz2cpu teardown
Offline DavidKo
  • Country: cz
Re: round 45mm photovoltaric ? where ?
« Reply #1 on: November 01, 2022, 12:20:50 pm »
Are you sure that the detector is damaged? Maybe you can try to connect the meter directly to the cell and measure the current. It can be bad contact. between cell and wiring.
Edit: or something can be shortening the photocell.
« Last Edit: November 01, 2022, 12:44:41 pm by DavidKo »
« Reply #2 on: November 01, 2022, 10:00:00 pm »
like i show in the video, the meter works, but the sensor dont deliver any current,
the sensor deliver plenty of voltage when unloaded, but the meter unly use very little current,
in the range of what i guess it normal for that time,
so i am sure it is the sensor it self,
i think it was allready up before, something about photovoltaric, specially the old ones dont live forever.
Online jdragoset
« Reply #3 on: November 02, 2022, 12:25:23 am »
Plenty of these
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2505460.m570.l1313&_nkw=weston+light+sight+meter&_sacat=0
out there elements appear to be 45 mm
Check with DVM on milliamp scale connected to sensor for current output.
The Weston elements use circular contact rings that are subject to contact resistance problems.
Since the back side of the sensor disc is directly connected to one wire, the front contact ring may be high resistance.
Try slight rotation of the sensor disc while slight pressure is applied to the back spring.
The Weston 703's function can be restored by slight rotation of the top glass.
The following users thanked this post: oz2cpu
