Author Topic: R&S CMU200 front module upgrade (FMR5 to FMR6). Possible?  (Read 1789 times)
Offline VelundTopic starter
« on: September 01, 2017, 01:43:32 pm »
Hello!
I have older CMU200 unit with FMR5 (AMD-based) processor board, very "tired" LCD backlight and keyboard, and a number of other blemishes. PS/2 keyboard port on the back of instrument. Got offer for a complete front with FMR6 (Celeron) from unit being parted, that also have PS/2 on the back.
Is it possible to simply swap front modules (FMR5 to FMR6) and have a working unit? Is serial number of unit stored somewhere on motherboard or CPU board have the serial "on the board"?
« Last Edit: September 01, 2017, 05:43:22 pm by Velund »
Offline Bicurico
  • Country: pt
    • VMA's Satellite Blog
Re: R&S CMU200 front module upgrade (FMR5 to FMR6). Possible?
« Reply #1 on: September 01, 2017, 04:48:56 pm »
I am by no means the best person to reply, but I think you can actually swap the module - it is just a PC, by all means.
Even if it is not compatible, it would probably be worth it for the LCD alone... Depending of the price.
Regards,
Vitor
Offline eb4eqa
« Reply #2 on: September 03, 2017, 09:06:10 pm »
It will work. I have interchanged them and found no issues.
If your main issue is the backlight, you may very well find another aged one in the replacement front panel. What I recommend is to upgrade the backlight to LED. Amazing improvement:
http://www.rbarrios.com/projects/LCD2LED/
Regards,
Roberto
« Reply #3 on: September 03, 2017, 09:31:25 pm »
Replaced it yesterday, with moving old HDD from FMR5 to FMR6. No problems observed. Backlight is way brighter that I had on FMR5 (almost unusable with a daylighjt during sunny day).
Another problem was keyboard - after a week without use, keys (especially the row under the display), stoped to work at all. I had to "massage" each key until it started to work. Cleaning conductive pads with alcohol, using soft cloth, helped not so much.
