Oh god what I bought.
First I want to check connection between frontend and MB. WTF, where is flat cable?
O.k. I found suitable cable and restore connection. Power up cmu and booting pass through stuc error. Serial and model number is showing.
YES and then
![[SOLVED]R&S cmu200 HDD image file wanted. 1306181-0](https://www.eevblog.com/forum/index.php?action=dlattach;topic=295454.0;attach=1306184;image)
and
![[SOLVED]R&S cmu200 HDD image file wanted. 1306187-1](https://www.eevblog.com/forum/index.php?action=dlattach;topic=295454.0;attach=1306190;image)
O.k. I boot to version manager and select options:
-clear nvram
-flash when board is changed
Same errors.
Then I was again boot to version manager and install older SW.
It looks o.k. Booting finish and all looks good.
After that I again change SW version to 5.00 and same errors appear. So What is this "overlay.c" related.
Ok, I was again downgrade version to 4.0 and looks all o.k.
I run self tests and all pass exept RF loop. (internal and external).
It is look like RF1 and RF2 ports are busted. But let this for later.
What do you think is to do. Try to upgrade to latest ver. or I leave 4.0.
