Author Topic: R&S HMC8012 - ripped connector and now no connection to main board, measurements  (Read 554 times)
Offline jmibkTopic starter
  • Country: at
a collegue gave me a HMC8012 to try a repair on. The connector to the front panel was ripped from the main board. There are some pads missing as well.
1628152-0
I cleaned everything up, replaced the connector and soldered a new one back on. The missing traces are replaced with some fine transformer wire.
It has to work, not to be pretty.
1628158-1
After putting the boards together and fixed them in the frame, I tried to buzz out every single connection - they look fine.
After powering it on, the LCD shows normal stuff but:
- the buttons on the right (V, I, Ohms,...) are verry laggy.
- no measurements on the screen
- after firmware upgrade, it got stuck by updating the main board firmware
1628164-2
That means, it has no data connection to the main board (or the mainboard is dead).
I checked the voltage and fuses, that power the aquisition circuit - they seem to be ok.
Does anyone has a circuit diagram or service manual to the bench top meter to trace out which connections are what on that board to board connector?
« Last Edit: October 31, 2022, 12:22:42 pm by jmibk »
Offline thm_w
  • Non-expert
Unlikely anyone will have a schematic.
I see some complex traces like this one, it might pass between and connect to another pad, are you sure you repaired these?
