Author Topic: R&S SME03 firmware  (Read 1299 times)
Offline JarekTopic starter
R&S SME03 firmware
« on: March 07, 2021, 11:06:27 pm »
Hello everyone
I need the firmware for the SME03 generator.
Can someone help me please?
Offline picburner
Re: R&S SME03 firmware
« Reply #1 on: March 08, 2021, 06:01:36 am »
This should be it (v4.12?) , however double check it before installing.
« Reply #2 on: March 08, 2021, 07:53:01 pm »
Thank you for your answer.
I follow the description but unfortunately there is no .hex file in the SMEENG folders.
I don't know what I'm doing wrong?
Regards Jarek
Offline picburner
« Reply #3 on: March 08, 2021, 09:34:49 pm »
The firmware is the file "sm3.bin" and it is transformed into sm3.hex by the DOS batchfile "update.bat".
Of course, everything must run under pure DOS, not under Windows 10 x64....
« Reply #4 on: March 11, 2021, 07:04:06 pm »
I used a pure DOS 6.22 computer
unfortunately there are still no HEX files to select in the folders.
I don't know what to do next.
Regards Jarek
Offline picburner
« Reply #5 on: March 12, 2021, 08:01:59 am »
I don't own this instrument so I can't help you further.
The complete service kit for your instrument can be found here.
From there I got the firmware.
« Reply #6 on: March 12, 2021, 09:59:55 am »
Thank you so much for your help.
I already have this software from this website.
I converted the SO3.bin file to SO3.hex and manually uploaded the software.
Unfortunately, damage to the processor board. is more
complicated. (I bought a damaged one, I thought to fix it, but I think it remains to buy a working CPU board)
The damage gives an error message as in the photo.
Best regards Jarek.
« Reply #7 on: March 17, 2021, 11:38:05 am »
I fixed the generator.   ;D
It was necessary to replace the EPROM memory from 1024 to 2048 and manually enter the " UPLOAD SMEENG " command in DOS.
« Last Edit: March 17, 2021, 10:17:11 pm by Jarek »
Offline picburner
« Reply #8 on: March 17, 2021, 08:37:17 pm »
Good job!
I had read something in the instructions about old pcb with less Flash memory but I didn't know which version you had.
« Reply #9 on: March 17, 2021, 10:20:56 pm »
I also did not know what EPROM memory I have until I removed the sticker on it.
best regards
