yes, this is the right software, you need some prerequisites, I quote:
"required:
Mathworks Matlab Runtime Engine Version 7.14 (R2010B)
(must be installed separately)
Features:
- R&S SMx-K63 User-defined frequency response correction for R&S SMU200A and R&S SMATE200A (requires SMx firmware 2.04.104.45 or higher).
- Service frequency response corrections for R&S SMU200A, R&S SMJ100A, R&S SMATE200A, R&S SFU, R&S AMU200A, R&S AFQ100A and R&S AFQ100B.
Further details and the devices required for the corrections can be found in the manual.
For correct operation, we recommend the following installation sequence:
1. driver for the GPIB card.
2. National Instruments or Agilent VISA library (only required for remote control via USB or LAN).
Recommended versions:
- NI Visa 3.4 or higher
- Agilent IO library M 01.01 or higher
3. Mathworks Matlab Runtime Engine Version 7.14 (R2010B).
4. SMx RF and BB correction toolkit.
5. NRP Toolkit and the NRP-Z driver for VXI Plug&Play (only required for NRP-Z).
- NRP Toolkit 1.5.7 or higher
- NRP-Z VXIPnP driver 1.6.2 or higher."
if you have found Mathlab 714, I would be interested in it.
Edit:
I have found Matlab 7.14, now I could install the R&S programme, to run it asks for the 7.14.SP2 and suitable DLL's...
