Author Topic: R&S SMU200A calibration software  (Read 1089 times)
Offline drhexTopic starter
« on: June 03, 2024, 07:58:17 am »
Hi all,
I have a new (to me) SMU200A which I'd like to calibrate. I think there is a software package similar to the SMIQ which I can't find anywhere. Can someone please share that with me?
Thanks,
Florian
Re: R&S SMU200A calibration software
« Reply #1 on: June 07, 2024, 08:41:00 pm »
Bump
Offline squadchannel
  • Country: jp
  • deepl translate user
« Reply #2 on: June 08, 2024, 04:21:33 am »
External Adjustments Requiring Measurement Equipment
The external adjustments require calibrated equipment and special software. Data sheet specifications
of the unit are concerned. If required, contact your local Rohde & Schwarz representative.
It was mentioned in the service manual. you might want to contact Rohde.
« Reply #3 on: June 11, 2024, 03:32:41 pm »
I have a ticket open with Rohde but am not hopeful. There is a tool for download in the software section to adapt levelling which could be the one but would like to know for sure.
Offline KeBeNe
« Reply #4 on: June 12, 2024, 03:46:56 am »
yes, this is the right software, you need some prerequisites, I quote:
"required:
Mathworks Matlab Runtime Engine Version 7.14 (R2010B)
(must be installed separately)
Features:
- R&S SMx-K63 User-defined frequency response correction for R&S SMU200A and R&S SMATE200A (requires SMx firmware 2.04.104.45 or higher).
- Service frequency response corrections for R&S SMU200A, R&S SMJ100A, R&S SMATE200A, R&S SFU, R&S AMU200A, R&S AFQ100A and R&S AFQ100B.
Further details and the devices required for the corrections can be found in the manual.
For correct operation, we recommend the following installation sequence:
1. driver for the GPIB card.
2. National Instruments or Agilent VISA library (only required for remote control via USB or LAN).
Recommended versions:
- NI Visa 3.4 or higher
- Agilent IO library M 01.01 or higher
3. Mathworks Matlab Runtime Engine Version 7.14 (R2010B).
4. SMx RF and BB correction toolkit.
5. NRP Toolkit and the NRP-Z driver for VXI Plug&Play (only required for NRP-Z).
- NRP Toolkit 1.5.7 or higher
- NRP-Z VXIPnP driver 1.6.2 or higher."
if you have found Mathlab 714, I would be interested in it.
Edit:
I have found Matlab 7.14, now I could install the R&S programme, to run it asks for the 7.14.SP2 and suitable DLL's... :-//
« Last Edit: June 12, 2024, 02:35:32 pm by KeBeNe »
Offline smps
  • Country: sg
« Reply #5 on: August 24, 2024, 07:49:11 am »
could you upload Mathworks Matlab Runtime Engine Version 7.14 (R2010B)? thank you
« Reply #6 on: August 24, 2024, 08:16:39 am »
I got the software to run, PM me for the necessary DLLs. You need a vector analyzer though which I don‘t have (and which would need cal, too). I sent mine off for cal in the end.
The following users thanked this post: KeBeNe
