Author Topic: R&S ZVB8 VNA  (Read 1338 times)
Offline fjullienTopic starter
R&S ZVB8 VNA
« on: May 18, 2024, 07:27:37 pm »
I've got a ZVB8 VNA, it shows an error message when the application starts: "Hardware detection failed!"
Does anyone has a ZVB8 and can check if the device manager shows something more than mine (see attached screenshot) ?
I was thinking I could reverse the application to see what is checked before it starts but it's not the easiest way to start fixing this device...
Franck.
« Last Edit: May 18, 2024, 07:52:48 pm by fjullien »
Offline Gerhard_dk4xp
Re: R&S ZVB8 VNA
« Reply #1 on: May 18, 2024, 09:30:45 pm »
I do have one, but its power supply is broken...
Gérard
Offline Jarek
Re: R&S ZVB8 VNA
« Reply #2 on: May 18, 2024, 11:01:16 pm »
Hello
Nice equipment, how much does something damaged like that cost?
I have been looking for a low budget VNA for some time now.
Where do you buy these?
Best regards Jarek
Re: R&S ZVB8 VNA
« Reply #3 on: May 19, 2024, 03:10:41 am »
 I paid sth. like €10K + VAT for it in working order, had to
re-import it from Asia to Germany maybe 8 years ago.
I found a switch mode power supply for €1K + hefty
€500 for transport; someone else seems to have
bought it.   >:(
BTW I copied the hard disk to a small SSD, block-wise.
So at least the software should be able to be recovered.
« Last Edit: May 19, 2024, 03:18:27 am by Gerhard_dk4xp »
Re: R&S ZVB8 VNA
« Reply #4 on: May 19, 2024, 07:02:03 am »
I didn't pay mine.
It came from another part of my company. During transport, it got broken.
I need to open it completely to see if I can spot something obvious.
Just opening the top and making a visual inspection shows nothing.
Offline Harry_22
  • Country: hn
Re: R&S ZVB8 VNA
« Reply #5 on: May 19, 2024, 09:18:35 am »
Hi Gérard!
If you are going to repair the power supply I can help.
The following users thanked this post: Gerhard_dk4xp
Offline Harry_22
  • Country: hn
Re: R&S ZVB8 VNA
« Reply #6 on: May 20, 2024, 08:16:47 am »
Hi Franck!
Let you see the screenshot.
« Last Edit: May 20, 2024, 12:04:45 pm by Harry_22 »
Re: R&S ZVB8 VNA
« Reply #7 on: May 20, 2024, 12:54:35 pm »
Thank you !
So I'm missing "R&S SMBus Device" and something under "Ramdisk".
Can you please expand the Ramdisk item and get details about the device ? Also for the "R&S SMBus Device" ?
Offline Harry_22
  • Country: hn
Re: R&S ZVB8 VNA
« Reply #8 on: May 20, 2024, 02:14:35 pm »
Ramdisk
            Windows RAM Disk Controller
 Device ID ROOT\RAMDISK\0000
 Hardware ID ramdisk
Re: R&S ZVB8 VNA
« Reply #9 on: May 20, 2024, 06:16:11 pm »
Thanks.
No sure it'll help, I'll post here if I find something.
Offline Harry_22
  • Country: hn
Re: R&S ZVB8 VNA
« Reply #10 on: May 20, 2024, 06:34:08 pm »
Seems that main problem is missing SMBus Device.
Let you start with the simple things.
-First, check all supply voltages (please see the picture). The power supply here is very reliable and the absence of one voltage is very rare. But do it anyway.
-Then check the fuses on the connection board. You access them from the bottom of the device.
-And finally I suggest removing the internal device modules one by one and checking the appearance of SMBus.
Re: R&S ZVB8 VNA
« Reply #11 on: May 20, 2024, 08:35:07 pm »
Power supplies and fuses are good.
I agree, this missing SMBus Device is a problem.
I do have an SMB Controller. Not the good one.
Its Vendor/device ID suggests that it's a ICH8 SMB Controller. However, the board has an ICH2...
My guess is that this device is in reality the Altera CPLD. It might implement a PCI device.
Could you check what driver is used for your R&S SMB Device ?
Offline Harry_22
  • Country: hn
Re: R&S ZVB8 VNA
« Reply #12 on: May 21, 2024, 02:18:45 pm »
Perhaps this is a different version of the controller. I checked several ZVB20 and they are identical (please see the picture).
I also installed Win_XP on separate 1091.2814.00 controller featured by 82801BA southbridge. It shows the same 2443 system device.
Do you know your controller number?
« Last Edit: May 21, 2024, 03:52:58 pm by Harry_22 »
Offline Harry_22
  • Country: hn
Re: R&S ZVB8 VNA
« Reply #13 on: May 21, 2024, 05:26:03 pm »
I disconnected all the modules including both ports. Software started but terminated different way. Without hardware detection fail window.
PS
It would be good to run your image on standalone controller.
« Last Edit: May 21, 2024, 07:15:05 pm by Harry_22 »
Re: R&S ZVB8 VNA
« Reply #14 on: May 21, 2024, 07:59:01 pm »
That's exactly the same chipset. I've run CPU-Z and I get the same result as what you posted.
My mother board has a different part number (1091.2908.00) but I can't see any difference (except the CPU fan).
Could you try to see what device driver the "R&S SMBus Device" uses ?
I'll try to run the software in "standalone" mode, with the bare mother board.
« Last Edit: May 21, 2024, 08:03:53 pm by fjullien »
Offline Harry_22
  • Country: hn
Re: R&S ZVB8 VNA
« Reply #15 on: May 21, 2024, 08:14:43 pm »
Could you prepare the image and send me a link.
 will run it on my MB.
Re: R&S ZVB8 VNA
« Reply #16 on: May 21, 2024, 08:17:29 pm »
Ok, thanks !
Any preference/recommendation for the HDD cloning tool ?
Re: R&S ZVB8 VNA
« Reply #17 on: May 21, 2024, 10:07:24 pm »
I attached the ZVB hard disk to a Linux workstation and simply
used the standard command dd. (disk dump, if =input file...)
root@silver>  dd if= /dev/sdc1  of= big_file.bin
and then with the new disk  and the order of the files reversed.
That worked. In Linux/Unix a drive or partition can be used
as just a huge file. Triple check the device names. You can
easily kill your Linux filesystem by giving the wrong names.
I first used a Digitus board for the copy, that produced a broken
file system. You may be tempted to use a huge SSD as the new
disk. That may stress the limits of Win XP, esp. without the
disk size service pack.  A 256 GB Samsung SATA SSD worked instead
of the 160 GB Toshiba laptop sata that was in the ZVB. I made the
1st partition on the SSD  slightly bigger than required and left the
rest unallocated.
midnight here,
Cheers,
Gerhard
« Last Edit: May 21, 2024, 10:12:19 pm by Gerhard_dk4xp »
Offline Harry_22
  • Country: hn
Re: R&S ZVB8 VNA
« Reply #18 on: May 22, 2024, 08:01:57 am »
Re: R&S ZVB8 VNA
« Reply #19 on: May 23, 2024, 05:28:45 am »
Thanks Gerhard and Harry.
Harry, I sent the link to my disk image in your DM.
Re: R&S ZVB8 VNA
« Reply #20 on: June 02, 2024, 08:35:41 pm »
With the help of Harry, we found that the problem was a corrupted image on the hard drive.
It had nothing to do with any peripheral not being present....
I used a new image, copied my calibration settings and boom ! No problem anymore  :-+
Thank again Harry and Gerhard.
Franck.
The following users thanked this post: Harry_22
