There are no components on the other side of the pcb. Only traces.
I drew some of them.
The Vcc pin of the part takes voltage from Input Voltage just after D2. These are pins 3-8.
Pin 1 also has similar voltage to Vcc due to R12. Too many pins IMO. Maybe there is an inside shortcut. Device fault comes after a wrong power adapter was used.
The Gnd pin is 6
Q1 collector is connected to pin 2.
Seems that LTC6257 doesn't meet the requirements...
