Author Topic: Russian car amplifier AAB-7900.1D  (Read 1545 times)
Offline Jeff eelcrTopic starter
« on: March 10, 2023, 01:17:09 am »
Customer cleaned the heatsink and off came all identification of model.
Amp has two power supplies with all conections, seperate output is single channel.
N ch enhanced TO-220 MOSFETs are marked H1 internal diode reads .470 and
Vgs is 3.14V that is pretty much all I can test for so far and do not know how to test
for RDS on nor have equipment to measure it.
  Owner found his manual so I have the model as added in subject.
Deaf Bonce Apocalypse AAB7900.1D russian company, made in china sold all over
the world. 7900 watts RMS @ 1 ohm still stuck on a replacement MOSFET for the
power supply
« Last Edit: March 15, 2023, 12:24:18 am by Jeff eelcr »
Offline shakalnokturn
Re: Russian car amplifier
« Reply #1 on: March 10, 2023, 10:12:09 am »
And... The MOSFETS in the DC-DC are blown? You would like to
replace them but don't know what to fit? Or nothing is wrong but you're just trying to identify the amplifier model?
Sorry I don't see the point behind this topic.
The following users thanked this post: timenutgoblin
Offline Swake
« Reply #2 on: March 10, 2023, 02:49:07 pm »
What can we help you with?
Post some pics of that thing, we might be able to identify it.
Is it OEM to the car, what brand is the car?
Is it aftermarket?
When it fits stop using the hammer
« Reply #3 on: March 11, 2023, 12:19:32 am »
Aftermarket not OEM.
Shorted MOSFETs that I can not identify.
Cant do pictures till next week.
Jeff
Offline james_s
« Reply #4 on: March 11, 2023, 12:50:39 am »
Mosfets in the DC-DC section? Your best bet if there are no non-shorted examples in the circuit is to either reverse engineer the circuit, or just look at what is used in a more common amplifier of similar power rating. Something like the IRF530 might work.
Re: Russian car amplifier AAB-7900.1D
« Reply #5 on: March 15, 2023, 12:48:32 am »
It was 1 of 8 that shorted on one side of power section so I
have 7 that work but very little experiance with MOSFETs as
far as design work goes with specs I can sub one IRF530 is
older part Vgs is in the area but voltage is high for this and
current is way low. I guess these at over 50A parts + some.
I have IRF3205 and IRFB4227 its not these.
Jeff
Offline james_s
« Reply #6 on: March 16, 2023, 04:12:11 am »
Personally I would replace all of them if I couldn't find a datasheet for the originals. Unless you want to pull one of the working original parts to analyze.
« Reply #7 on: March 16, 2023, 02:23:45 pm »
Certianly I will replace all of them but with what?
How do I test for specs on an unknown MOSFET?
The ones I have in stock are not good subs and
the highest current one I found in my 96 fet book
is 75A of coarse I do not have any to test.
All I know how to test for I listed in the first post.
Jeff
Offline james_s
« Reply #8 on: March 16, 2023, 04:52:15 pm »
Well you can guess. If you know the power output of the amplifier that gives you a good clue as to the power that the supply has to deliver. Failing that you can look at the rating of the input fuse and go off of that. It shouldn't really be that critical, these mosfets are likely two banks of parallel mosfets driving a push-pull transformer at a few tens of kHz. You'll want something rated for perhaps 100V at maybe 20-40 amps.
