So here's the TL;DR question, but I'll put the details below: If I removed one of four inductors/chokes from my GPU's VRM, should the core now be running at its minimum of 300Mhz instead of 1206Mhz? I was hoping I could run using three of the four power phases if I underclocked/undervolted the GPU.
Details: I bought a Sapphire RX 470 8GB mining edition (DVI-only) on eBay months ago. It had been used for mining and had a mining BIOS on it. The white sticker on the fan shroud says it's a "11256-57." The card turned out to be DOA, with both fuses for the 8-pin PCIE power plug dead. I contacted the seller and he gave me a refund and told me to keep the card. Thus began my adventure.
The behavior with PCIE power connector plugged in: Computer wouldn't fire up at all (because of PSU's over-current protection?).
The behavior with PCIE power connector not plugged in: Computer started just fine but only had the integrated graphics.
Impedance testing with multimeter indicated a short.
I know little about electronics, but wanted to learn. At this point I've bought and used for this project: A cheap hot air rework station, .5mm Chipquik solder, flux, solder wick, Littelfuses from China, and Fast Chip removal alloy. I've spent more on the card than it's worth, but it's all about life-long learning so it's worth it. Oh, and I bought another used Sapphire RX 470 4GB mining card (model 11256-58) from eBay so that I could compare voltage, impedance, etc. between the two cards. I replaced its mining BIOS with 193398.rom from TechPowerUp and it works great.
After watching hours and hours of videos (some of them repeatedly; some of them in Russian) and reading forums, I decided that at least one DrMOS was dead and I was pretty sure which one it was. It was then that my nightmare began. I could not for the life of me remove the damn FDMF3035 DrMOS ("integrated MOSFET plus driver power stage") with my $50 hot air station and limited skills. In fact, I accidentally dislodged a couple tiny passive components with the hot air while the DrMOS would never budge. I even tried using a heated frying pan and removed the card's bracket to help with the heat sink effect.
I read somewhere that I could disable one phase entirely and that the card should run without it. I saw that removing the through-hole capacitors wouldn't help in troubleshooting and that I'd have to remove the SMT choke. Again, hot air didn't do the trick (for me) so I bought the $20 tube of Fast Chip and HOLY CRAP that stuff works. In the photo below, you can see the dislodged choke, two tiny passive components hanging on for dear life, and the real culprit, a scratched-up FDMF3035 DrMOS that I couldn't remove.
With the choke removed, all impedance testing was suddenly perfect. Woo-hoo! I installed the card in my PC and got fan spin, and then powered it up and Windows launched. I then flashed with the closest BIOS I could find from TPU (209467.rom) as the installed mining BIOS displayed weird in GPU-Z. So to my question above about running on three out of four phases, is there any hack where I don't have to replace the DrMOS? Is the only path forward to replace that stubborn IC? I have ordered five of them from China and they'll take a month to arrive, but I wouldn't mind leaving the card as-is if I could run it at say 75% performance.
