Hello guys,
I have at hand two gpu s that ware used in mining. They are rx470 with 8gb from xfx. One is just fir parts ant the other one has some fat lines on the screen. I tried to reflow the main gpu but I have never done that and I was to afraid to heat up the gpu more then I supposed. After my attempt to reflow the gpu, nothing had changed so I tried using the gpu as it is.
After installing it in the computer, I was able to see that in device manager, the card was listed as basic video adapter. I downloaded the drivers and successfully installed them but then, every time the windows boots, the gpu goes black.
Is there any way I can fix this card, it may be the memory chips? As I seen that they are a bit toasty in the middle.
