Author Topic: S1-83 (C1-83) Oscilloscope Power Connector Repair  (Read 3596 times)
Offline WOOK.ltdTopic starter
« on: July 03, 2017, 04:37:09 am »
Hello everyone,
I've just got hold of an old Russian S1-83 (C1-83) Oscilloscope that requires some work to become operational. I've never seen a power connector of this sort (see Images attached) before so I was thinking of replacing it with something more standard to save time and hassle. The back panel shows the power input requirement so I'm fairly sure its going to be fine. However the cabling used for it doesn't look thick enough for power (although its only 50 watts so maybe its fine).
Has anyone seen this connector before or know if my plan is going to work?
I'm very new to this sort of thing and this is my first oscilloscope so it would be nice to get it up and running. If you have any questions about the project feel free to ask. Also if you want more photos or see something interesting let me know.
Thanks,
Will
Next stage:
I've tried to trace the two cables I believe to be active and neutral but haven't had any luck in finding where they terminate in order to distinguish the two. I'd prefer not unscrew to much as I fear I might not be able to put it back together considering the little information available.
I read that if the active and neutral are wired in reverse it can cause the chassis and/or other components to become live while the device is off. Therefore, I was wondering if it was possible to wire the device not knowing which wires are which and then testing to see whether the polarity is correct or not and then act accordingly. Or could this method damage the oscilloscope. (Pardon my ignorance)
« Last Edit: July 03, 2017, 11:39:45 am by WOOK.ltd »
Offline ElektronikLabor
    • YouTube: ElektronikLabor
Re: S1-83 (C1-83) Oscilloscope Power Connector Repair
« Reply #1 on: July 03, 2017, 06:54:27 am »
Nice scope and nice restoration project!  :-+
Does the power connector has only two wires attached? The two other pins are unused?
It should work fine if you can fit a standard C14 connector by mechanically reworking the metal cover.
Don't forget to connect the ground wire to the case of the scope.
The following users thanked this post: WOOK.ltd
« Reply #2 on: July 03, 2017, 07:23:55 am »
From what I can tell 3/4 pins were connected (one was broken off so you can't tell from the photo), so one is unused.
One lead goes directly to the chassis which I didn't expect because I thought the outside of the connector would be ground.
The problem now is that I don't know what each pin was because they're all the same colour. I might have to do some wire tracing to try make sense of it all.
If you have any more tips i'm all ears. And thanks for the reply.
« Last Edit: July 03, 2017, 07:36:06 am by WOOK.ltd »
Offline alm
« Reply #3 on: July 05, 2017, 04:55:45 pm »
I am not familiar with Russian earthing arrangements from that era. Were grounded outlets common in the era this scope was designed?
I would just trace the circuit from the power connector. I would expect some combination of wires going directly to case, to a switch and/or fuse, and to primaries of transformers. From this you should be able to infer the correct wiring. A wire going directly to the case is most likely ground and should have a high resistance to either of the other wires. The wire through the fuse/switch should ideally go to hot, and the wire going directly to the transformers to neutral, but the latter is not that critical (it would not surprise me if they originally used a non-polarized plug).
If one of the primary sides of the transformers is directly connected to the case, than you may have a hot chassis (neutral connected to chassis). That would warrant some care. But I would expect this scope to be way too modern for that. Test equipment (at least in Western countries) was usually more modern than consumer equipment in that regard.
Offline stj
« Reply #4 on: July 05, 2017, 05:26:01 pm »
you can probably get a mains rated connector from neutrik or bulgin that's the same size/shape
it most likely uses the body as the earth connection btw.
Offline Mickle T.
  • Country: ru
« Reply #5 on: July 05, 2017, 05:42:03 pm »
If it's helps a little, a full S1-83 schematic diagrams is here in DJVU format.
Offline alm
« Reply #6 on: July 05, 2017, 05:56:29 pm »
OK, so pin 1 is hot, pin 2 neutral, and both pin 3 and shield appear to be earth (do they measure as shorted?).
« Reply #7 on: July 16, 2017, 02:35:48 am »
Sorry for the late reply, I've wired her up and she turns on.
However, over a few minutes the intensity of the trace on the CRO slowly decreases.
I think its a capacitive issue. But before I go poking around has anyone encountered this before or got any ideas?
Also thanks for all the replies!
Offline alm
« Reply #8 on: July 16, 2017, 02:47:57 am »
I would start by measuring power rails (DC voltage and ripple, both shortly after power on, and after intensity has decreased). Could also be breakdown in the HV circuit. If that is the case, try not to leave it on for too long like that.
Offline stj
« Reply #9 on: July 16, 2017, 03:11:54 am »
i had a scope do that, it was a bad diode slowly increasing it's volt-drop as it warmed up.
a right bastard to track down, because it looked fine when metered cold.  |O
