Author Topic: TESTER SAEHAN ST-303 diagram  (Read 492 times)
Offline GhoghnoosTopic starter
  • Country: jp
« on: May 03, 2022, 10:17:41 am »
Hello. If anyone has an ST-303TRA analog multimeter circuit diagram, load it.In fact, one of its resistors is burned and I want to replace it, but the amount is not known
« Last Edit: May 03, 2022, 10:32:09 am by Ghoghnoos »
Offline BreakingOhmsLaw
  • Certified solder fume addict
Re: TESTER SAEHAN ST-303 diagram
« Reply #1 on: May 03, 2022, 01:36:50 pm »
They have a customer forum, you might try and ask there:
http://saehantester.co.kr/home/04_sub/02_sub.html
  • Country: jp
« Reply #2 on: May 03, 2022, 08:23:15 pm »
 thank you so much :)
