Author Topic: Safely replace FCC connector on TFT screen module?  (Read 1456 times)
Offline e-pirateTopic starter
  • Country: ru
    • www.e-pirate.ru
« on: January 31, 2016, 03:13:49 pm »
Hi, folks.
I wonder how to safely desolder 40 pin FFC connector from TFT screen module I have. I'm afraid of damaging the TFT matrix underneath the board while heating the connector with hot air station.
Any suggestions here?
** Think, research, design, experiment, create..
  • Country: ru
    • www.e-pirate.ru
Re: Safely replace FCC connector on TFT screen module?
« Reply #1 on: January 31, 2016, 04:41:42 pm »
Well, actually it wasn't so hard. I spent more time think on how to desolder it, then actually desoldering it. I cut two holding pins on the side with a paper knife and forced them out with soldering iron. Then solder blob technique did quite well in that particular case. Especially after realising that I can sacrifice the connector and brake it. But, unfortunately, I lost the replacement connector. It is simply disappeared into thin air :)
