I am repairing an SC502 TM500 series oscilloscope. One channel was faulty, having a lot of DC offset where you can't even center the trace. This was channel one, the faulty one. I narrowed down the problem to Q125, a dual N channel J-FET.
I "knew" Q125 was faulty because since both channels are identical, I swapped channel 2's J-FET and put it in the socket for channel 1's. Channel 1 worked just fine now, and when I put the "faulty" J-fet into the socket for channel 2, channel two was now faulty.
But when I put the FET's into my 5CT1N, both transistors were IDENTICAL. I made sure to check both transistors in each 6-legged package. Sure, there are some minor differences like one has slightly more gain than the other, but I do not think this would make such a huge effect that the channel with the "faulty" transistor gets a massive DC offset.
I just wanted to ask before spending $30 on ebay for a single replacement transistor, is the J-fet really faulty or is it something else that's wrong in the scope?
