Author Topic: Voltage issue on a Yamaha Tyros 2 keys matrix scanning board  (Read 593 times)
Offline dariodarioTopic starter
« on: February 03, 2023, 06:26:30 pm »
Hi, I'm trying to repair a Yamaha tyros 2 keyboard.
The problem is that all the couples the D# - A keys sound only the first time I press them. The second time I press them they don't sound anymore. The D# and A are on the same wires in the matrix scan as you can see from the attached schematics.
There is no interruption in the circuit D#-A (in fact the first time they sound) but some oxidation points.
I noticed (with reference to the attached schematic) that the pull-up 5V voltage in the EMKS-F board is present on all scan lines except on the D#-A line. In the D#-A line are present 1.1 V instead of 5 V. So this could be the reason of the D#-A not working keys.
With the board disconnected, I also noticed that measuring the resistance from the 5V line to the scan lines, all are about 32-33 Kohm (OK, as per schematic R30..R41), except on the D#-A line in which I measure about 20 Kohm. Unfortunately I cannot access to the hide layer of the board due to 2 connector that are difficult to desolder. That 33K smd resistors are on the hidden layer of the board.
Shouldn't I have 5 volt even if the SMD resistor changed its value from 33K to 20K, since it is connected as pull-up resistor?
Some suggestions please for desoldering this difficult connectors whitout damage the two layer board? The problem is that I need to remove the two at the same time to push out the board...
Thanks a lot.
Regards.
« Last Edit: February 04, 2023, 02:21:06 pm by dariodario »
Offline Audiorepair
Re: Voltage issue on a Yamaha Tyros 2 keys matrix scanning board
« Reply #1 on: February 04, 2023, 07:06:19 pm »
Well yes you should.
The most common problem with key PCBs is someone spilt something onto the keys and it leaked onto the PCB.
It sounds like you have a partial short to ground on this line, so look very carefully for any traces of liquid damage by following the line as best you can.
« Reply #2 on: February 06, 2023, 03:31:21 pm »
Audiorepair, you are right.
I cutted the main trace (D#-A) near the connector, and now the line is generating 5V as expected!
The problem now is finding the point of the partial short to ground, since 1/3 of the circuit is covered by the scanning board...
and just this 1/3 has the most number of vias. I think that the partial short is on one of that vias due to the nearness with the ground (shaped ground layer) and the oxidation I saw on that.
Regards.
