rg58, thanks for that reply. It does seem to make sense. The other day, the problem manifested itself by the affected channel having a lower volume rather than totally cutting out. It also seems more likely to happen if the amp is unused for a while, but not always. Sometimes I can turn the amp off and back on again and the problem happens immediately. Other times I cannot reproduce the issue - as was the case the other day when I had some time and took it to the workbench to have a look at! It is curious that when it happens, it doesn't require much volume to 'burn' it free, but then I guess it only takes a very fine layer of oxide. I tend to run it for background music so there is not much volume getting generated. It only seems to affect one channel so perhaps only one set of contacts is affected at this time. I will see if there is a way to remove the cover to have a look and clean it.
