Author Topic: Samson XP360B - Speaker replacement  (Read 335 times)
Offline lean032
  • Country: ar
« on: July 24, 2018, 08:06:27 pm »
Hi everyone!!!
I own a Samson Expedition Express XP360B http://www.samsontech.com/samson/products/portable-pa/expedition-rechargable/expeditionexpress/
I would like to replace the tweeter but I canĀ“t figure out how to remove the front panel to access to the speakers.
Can anybody help me with this???
Thanks a lot!!!
LF
Offline envisionelec
Re: Samson XP360B - Speaker replacement
« Reply #1 on: July 31, 2018, 07:44:38 pm »
The metal grille will be held in with hot melt glue or other sticky substance. Warm the entire speaker in direct sunlight then unfold 3 or 4 paperclips into a shape that can be looped through the grill in each corner. You can also use a pick-type tool. If the glue is soft, it won't take much pulling, but be persistent. The grill will come out eventually.
