Hey guys,
Just been given one of the above.
Fault: powers on, then gets crazy horizontal lines down a third of the screen, you hear a crackling noise then the backlight powers off.
Backlight is definitely off, can still see faint picture with torch.
Tried replacing most of the caps (none obviously bulging, leaking etc) (replaced caps feeding inverter), still fails, crackling noise definitely coming from inverter module (this monitor has integrated PSU / inverter). Part marked tms93682ct, doesn't seem to exist on the internet.
i would very much like to get this working again as the LCD panel is very nice, to replace the full PSU / inverter would be quite expensive, does anyone have any suggestions as to how go about further diagnosis / repair of faulty board ??
I haven't yet replaced the main AC cap or a couple of small caps elsewhere on the board and I can't seem to find a replacement for the inverter module. (I removed it from circuit and the secondary resistance tests pretty much the same / not open or closed.)
Any thoughts gratefully received..
