Author Topic: Samsung 32" curved ,garbled image only at cold start.  (Read 925 times)
Offline jonsigTopic starter
  • Country: is
« on: April 27, 2022, 11:03:32 pm »
Good day, fellow EET´s  and repair affectinatos ! :)
I have strange problem with 32" inch curved samsung monitor i got for free. (LC32HG70QQUXEN) and displays are not my stongest field.
Symptoms:
After the monitor is plugged in, the following is displayed.
1.Garbled image,
2.Those wide vertical segment appear one at a time with consistant interval, one after another.
Then after ~3 minuets the display appears fine, and stays like that even if it´s turned off and only in standby. I need to unplug the screen for a while so the problem appears again.
Work carried out:
Took random test of electrolyte caps with my peak ESR+ meter , every cap tested is in "OK" range. No ESR problem just slight degradation less than 10%.
Overall solder quality was good.
Flex cables re-seated and dont look damaged.
Im not sure what kind of failure mode i´m dealing with. Possibly BGA problem ?
tips woulld be appreciated.
« Last Edit: April 27, 2022, 11:24:27 pm by jonsig »
Offline RoGeorge
Re: Samsung 32" curved ,garbled image only at cold start.
« Reply #1 on: April 28, 2022, 08:29:34 am »
When something a couple of years old suddenly doesn't work only when cold, first thing, replace all the electrolytic capacitors with brand new ones.  Don't waste time measuring the caps, just replace them.
The following users thanked this post: jonsig
Online wraper
  • Country: lv
« Reply #2 on: April 28, 2022, 09:12:48 am »
Except the chance this having anything to do with bad capacitors is close to zero. Not to say this monitor was made much later than the time when bad capacitors were a widespread issue.
Don't waste your time needlessly replacing capacitors when you can easily measure ESR within circuit. The only case when you should replace caps with good ESR is when you know that particular series have problems or when other caps are bad.
« Last Edit: April 28, 2022, 09:18:17 am by wraper »
Offline 20Ola02
  • Country: no
« Reply #3 on: April 28, 2022, 01:46:35 pm »
Not much of any help, but I had the same problem on a 24" curved MSI monitor. At the beginning it only took 30 sec to clear the screen of the artifacts, but after 2 years of this happening when it was cold it took anywhere from 3-5 minutes to clear the screen. Trying to find a solution on a forum I came across a thread where they said it was a common thing and had something to to with a chip, cant remember the forum :palm:
Offline Rasz
    • My random blog.
« Reply #4 on: April 29, 2022, 12:36:00 am »
This dos look like a bonding failure on one of the ribbons
