Hi folks,
I found a Samsung 46" dumped on the side of the road. Missing remote, most of the screws were off the back... looked like someone had a go at it (at least looked at it on the inside but doesn't appear to have done anything). The panel looks in good shape as does the case, so whoever looked at it probably didn't do much other than open it and give up.
I popped the hood and could not see any obvious damage, caps look ok but I know that is not a reliable test. I have a cap tester and will have to check them. Plugged in the TV, the red "standby" light goes on. Tried the buttons on the front panel but they didn't do anything. Just in case the touchpanel was a problem, I tried using a universal remote as well as a couple of my other Samsung TV remotes (I have a few circa 2009 which is the age of this TV)... Did not power on, and nothing made the red standby light even blink.
So first obvious question, is this a CAP issue on the main power supply? Seems like the easiest thing to do is to simply test and replace all the caps (the 2 large ones, 5 medium and 4 small ones) and see how it goes. I've done that on a few other TV's, an XBox, an LCD monitor and it has fixed them.
My main family TV is a Samsung 42" from around the same time (2007) and I had to change 2 caps on the main power board around ~2010-2011 and it is still working now 10 years later. If can get this 46" to work I can replace our family TV with this bigger one. When my 42" Samsung failed, it had a standby light and would turn on but click and blink the red light but the screen would take minutes to turn on, until eventually it didn't want to power up. But at least it "tried" to boot up (some activity).
Whereas this 46" TV doesn't show any indication of even responding.... so could it still be a simple Cap issue? On this TV the front-panel buttons (I assume some kind of "touch sensitive" panel) as well as a few Samsung and Universal Remotes I tried did not seem to create any response, no red standby light blink. So is it a CAP issue or something with the micro handling the power on routine? What should I be doing first?
I've attached lots of photos which may help, which I'll span across 2 emails due to file size restrictions per post.
