Quick lesson when testing with oscilloscopes as I noticed you are learning in this area. First watch that how not to damage your oscilloscope video a few more times. It is not safe to connect most oscilloscopes to mains circuits at all, it warns against this in their manual. Most oscilloscopes have exposed common BNC ground connections on them. Not only do you need to be careful of input voltages you need to be careful about putting voltages onto the oscilloscope ground which creates a dangerous touch hazard as well as damage equipment.
It helps understand that ground, earth, common, negative, neutral are all labels give to points of a circuit that may be at different potentials and create shorts when connected to each other. You have to be really careful connecting the oscilloscope ground lead (real earth/ground in most countries) to points on the PCBs which are not actually the real earth/ground because it can act like a short.
You would think it's safe to hook up ground lead to the secondary, it's low voltage right? No only if the ground lead goes somewhere where it doesn't create a short to mains earth/ground. Think of the oscilloscope ground lead always as a short creating wire to earth/ground.
So then you find a nice low voltage floating voltage/signal and you connect your oscilloscope ground to it (creating a ground to reference your measurements off) and are observing that signal on your oscilloscope. The moment you attach any other equipment you need to consider does it have another ground/earth connection, and are you making a short with it.
Want to use a second channel on the oscilloscope? Since the ground leads are common you have to connect them at the same potential. If you don't and there is a voltage potential between those two points, you have created a short and bad things will happen.
It gets easier once you understand the concept and reading and understanding schematics helps. If you see several components between two points on a circuit that is a dead giveaway there is going to be a difference in voltage potential and they are not electrically common.
Hope this helps.
