Author Topic: Samsung front-load wash machine On/Off button cannot get on supposedly  (Read 254 times)
Offline marhuumTopic starter
  • Country: kh
Samsung front-load wash machine On/Off button now could get contacts ie. pressing it is toggling On/Off
But most of the time it won't get on immediately, instead it only yields weak sound sort of:
tuck.. tuck.. tuck
every 2 sec in between each
and will only really get on after 9 minutes or so
Has one gone through such case on similar kind of control panel system so can benefit on this here?
NB:
sequal of https://www.eevblog.com/forum/repair/whole-glued-pcb-taking-apart/
Online indeterminate
Re: Samsung front-load wash machine On/Off button cannot get on supposedly
« Reply #1 on: January 26, 2025, 10:14:18 am »
It is probably an electrolytic capacitor in the standby power supply.
The following users thanked this post: amyk
  • Country: kh
« Reply #2 on: January 26, 2025, 10:27:05 am »
Seems every one's mind quickly, easily thinks it's the issue on filp-flop capacitor responsible for the on-off data,  but how exactly troubleshoot to correctly pinpoint and fix it..
« Last Edit: January 27, 2025, 07:15:50 am by marhuum »
« Reply #3 on: January 27, 2025, 06:42:06 am »
The translation is difficult to follow.
Yous an ESR meter to test the electrolytic capacitors in circuit.
there will be one on the input and output buck converter ic
