Author Topic: Samsung Galaxy S8/S8+ battery temperature warning fix  (Read 385 times)
Offline poot36Topic starter
« on: December 31, 2022, 02:55:32 am »
If you have a Samsung Galaxy S8 or S8+ cellphone that when you plug it in to charge it shows a temperature warning symbol on the screen and does not charge then you may have a damaged NFC/wireless charging antenna cable.  The problem is that the temperature sensor for the battery is also on the flex PCB with the NFC/wireless charging antenna on it and it is very easy to damage when the battery is replaced.  I have not found this information online so I hope it will help someone get there phone charging again.
