« Reply #5 on: June 24, 2016, 05:29:17 am »
Well it is Linux all the way on these drives.
After familiarizing myself with a couple of versions of Linux... Debian, Ubuntu and creating the "Live" installations.
Then learning a bit about two programs, that are quite new to me... gparted and hdparm.
I was able after a few more attempts to put this process in the right order and create a useable 500 GB drive for free.
Process is:
1. Initialize/Power up drive in Direct TV DVR box.
2. After power up, Hot swap SATA cable to computer. ( I used laptop and USB to SATA module )
3. Open gparted find the drive /dev/sdX. ( X your drive letter )
4. Delete all partitions on the drive. (there were 4 different partitions on my drive)
5. Create new partition in the format you require, ie. NTFS, Fat32 and many other choices.
6. Apply the changes through the checkmark menu item. ( very nice feature that saves from mistakes )
7. Close gparted.
8. Back to the terminal window.
9. Enter Sudo su
10 Enter hdparm -s0 /dev/sdX
11. Receive successful Spin up "off" response.
12. Unplug your drive from the Direct TV box
13. Plug into new power supply .
14. Plug drive into computer and there you have it.
This was discarded unit dated 2008.
« Last Edit: June 24, 2016, 05:35:27 am by Johnny10 »
Logged
Tektronix TDS7104, DMM4050, HP 3561A, HP 35665, Tek 2465A, HP8903B, DSA602A, Tek 7854, 7834, HP3457A, Tek 575, 576, 577 Curve Tracers, Datron 4000, Datron 4000A, DOS4EVER uTracer, HP5335A, EIP534B 20GHz Frequency Counter, TrueTime Rubidium, Sencore LC102, Tek TG506, TG501, SG503, HP 8568B
