Hi All,
I am repairing a sound bar for someone, they said it "stopped working" describes most faults really doesn't it.
I found the mains power input to have had some trauma and the PCB to be cracked, i bridged the joints with solder and I am now getting power, it references a 3.15a fuse on the main board twice, and on another forum i was told "its the yellow rectangle" but as i have replaced a load of Rifa capacitors in the past, and it has a rating of 0.33uF and i have never seen a fuse with a Farrad rating i can only assume that it is indeed a filter cap.
I replaced the yellow filter cap temporarily with one from a PC PSU, 0.22uF x2 safety cap and i got the same voltages across the board, mains at 235v and the output from the cold side of the board at 22v (caps on this side are rated at 35v) so i imagine thats somewhere close.
Im running out of ideas now, the power goes from this mains board into the sound output/mini display/power volume and input select board, but it still does not come on at all, there is a certain electrical smell inside but not what i would call Rifa catastrophic death smoke smell, just warm electronics smell sort of.
Any help would be greatly appreciated - Joe
