Go around checking each power supply everywhere in the unit to see which one tries to come up when the thing dies. There are
MANY local regulators in most of these units.
These kinds of problems are almost always locatable by tracing the sectional power rails and regulators. Whatever section is going active when it dies during initialization is the area of circuitry to check. Sometimes it is non-obvious, or you go down the wrong path by not getting specific and local enough to find the (in hindsight) glaringly obvious problem. It took me
days of messing around to realize where the problem actually was on a few units over the years, like with this Samsung plasma issue, for example:
https://www.badcaps.net/forum/showthread.php?t=43075For most people it seemed to be mostly one cheap MLCC capacitor playing up, occasionally IC itself, but once you realize
what general circuit section is at fault, it's usually pretty easy (and cheap) to solve.
You still never mentioned before whether when you disconnect the backlight board from the PSU board if the backlight power on the PSU side actually comes up full? If not, pull whatever transistor is driving those transformers on the PSU going to the backlight in case there is a shorted turn in one of the transformers or something. I've seen this several times on LGs with the CCFL tube backlights.
If you do suspect it's audio related (it IS playing the chime, after all) it is usually the amplifier section that causes issues and you can just disable the power to it, but if there are common IC issues on these sets, you might be able just hot-air the chip off and see if the behavior changes. You've nothing to lose by hacking up a free "junk" TV. If you at least find out where the problem lies, you can often just grab a used board for $40 as a permanent fix once you know the set is actually
capable of running if you've hacked up the original board in your sleuthing efforts.
