Author Topic: Samsung monitor U28E590D high pitched noise  (Read 1671 times)
Offline zybreakTopic starter
« on: August 17, 2019, 12:14:11 pm »
Hi
I'm trying to get rid of a high pitched noise coming from the motherboard of my Samsung U28E590D computer monitor.
The noise is there regardless of whether I have plugged in any video inputs or not (although with an input plugged in the noise does change character)
Its hard to pinpoint which component is making the noise, and I would like your help to identify the components on the bord and maybe even point me in the right direction of the most probable offender.
I'll attach a picture of the area of the board where the noise is coming from.
Offline amyk
Re: Samsung monitor U28E590D high pitched noise
« Reply #1 on: August 18, 2019, 02:55:49 am »
It's almost certainly one of those big inductors.
You can roll up a piece of paper and use it as a stethoscope.
Offline Rasz
    • My random blog.
« Reply #2 on: August 18, 2019, 04:56:36 am »
or plastic straws
also listen to small smd caps
fix might be as simple as a coat of lacquer
