Author Topic: samsung NP530U3C-AD5BR laptop does not charge battery  (Read 919 times)
Offline eletmoraesTopic starter
  • Country: br
« on: August 18, 2018, 12:26:16 pm »
platform: BA41-02040A
N Y BA41-02022A
GCE BA41-02021A
The owner of the notebook changed the battery by putting one of the bestbattery but the problem continues.
I searched the internet and found this battery to buy only that I saw that the wires of the 9-pin connector differ from one battery to another according to the attached images. Maybe the problem is in the battery or in the charges circuit.
voltage at the J506 connector pins (lithium battery connector):
pin 1 --> 3v
pin 2 --> 3v
pin 3 --> 3v
pin 4 --> 3.38v
pin 5 --> 3.38v
pin 6 --> 2.61v
pin 7 --> GND
pin 8 --> GND
pin 9 --> GND
obs: only obtained using the AD4019A power supply and without the use of the lithium battery
I ask colleagues, what is the correct voltage of all the pins of the BQ24735 when I am not using the lithium battery?
