There is no cap on the input. That one in between the two diodes is just.. eh... not right where I'd rather see it.
The circuit seems to be designed to fail. The 1117 regulator can accept 16 volts maximum. There is quite probably about 17volt input, shunted with the two diodes to get just about the 16 volts needed.
If I remember it right 17V is a common voltage in LCD monitors for powering the CFL inverters - please correct me if I am wrong! I'm not sure now, I think I've seen the 17 volt voltage in some monitors... If it's not true, please forgive, I usually avoid monitor repairs, this stuff is too much boring for me do I don't know much about :-)
The second possibility is that it might be just at about 5V input voltage or so and they've used the diodes to decrease the heat dissipation on the regulator. Neither this is an excuse, because still it overheated and finaly blew. Still it was designed wrong or purposely to be likely failing a day or two after the warranty expires.
By the way, I'd be concerned about the circuitry connected after this blown vrg. It might be blown too, bcs of the failed regulator.
Rasz: Yea
