Author Topic: Samsung plasma tv repair  (Read 1030 times)
Offline Don’t lose the smoke PhilTopic starter
« on: December 07, 2023, 05:51:14 pm »
Need help to figure out TV repair. I have replaced the XBUP board then blew fuses! Model number is
FPT6347X/XXA  or internal model # S63FH- X801
« Last Edit: March 27, 2024, 09:32:54 pm by Don’t lose the smoke Phil »
Offline DavidAlfa
Re: Samsung plasma tv repair
« Reply #1 on: December 07, 2023, 05:56:56 pm »
Start by disconnecting everything and powering the PSU alone.
If the fuse survives, proceed connecting the mainboard, then the others, but only one a a time, until you find the one blowing the fuse.
« Reply #2 on: December 07, 2023, 06:10:44 pm »
Thank you for the reply. Sorry to be such a newb but need clarification. Psu is power supply unit? The power cable comes into the TV and then goes directly to a very big pcb that i assume is the main board. So disconnect all out going cables to like the x main y main etc? I have a service manual for a Samsung plasma tv but it is not my model . I’ve looked but found no specific manual for my model. That would really help me out if you knew where i could look for that! I need to get a couple of fuses still. Could you recommend source for reasonable small electronic parts? I miss my neighborhood Radio Shack! It was four blocks from my house and i could quickly get little things there quickly. Amazon, eBay ali baba aren’t priced reasonable or shipping is more than the fuse!
Offline DavidAlfa
« Reply #3 on: December 07, 2023, 06:32:24 pm »
Yes.
Yes. The connect only one board at a time.
Offline fmashockie
« Reply #4 on: December 08, 2023, 06:46:52 am »
Nothing comes up when I google FPT6347X/XXA.  Look for a label on the chassis of the plasma TV.  Once you have the back cover off.  There should be a different model # there.  It may lead you to a service manual.
Mouser or digi-key are good places to source electronic components.
« Reply #5 on: March 27, 2024, 10:26:04 am »
I have acquired all necessary fuses. Is there any suggestions about where to check for why fuses blow?
