I found
https://www.eevblog.com/forum/repair/samsung-32-s32d850t-monitor-repair-story/ while searching for reasons why a dumpster-rescue monitor is failing.
https://www.eevblog.com/forum/profile/?u=495603 (@sausage) has been helpful through private communicaiton but I thought I'd ask more here. (Can you tag users on this forum?)
The unit works, but will power down at arbitrary times. Can be a few minutes, can be longer.
The PC announces that the monitor has been unplugged and reconfigures the displays as if it has been removed.
All panel buttons are inoperable.
Pulling mains power and waiting a few moments, it can power on again.
I hypothesize that the KF12N60F MOSFET is marginal, since that seems to be a common failure, so I ordered one, thought it will take a long time to arrive.
Any suggestions of interim things to try?
I chipped away the silicone (?) adhesive. I know some adhesives from distant past times, some adhesives have become conductive by breakdown or contamination over time. Is that a possibility here? I'm presuming not, but all that goop on the metal leads have me pause. I wonder why this part fails so often? Should I look for an upgraded part?
I also plan to use CPU grade heatsink compound on the reinstall.
I welcome any thoughts.
