I heard that SMPS or a pain, but I never thought it would be like this. I've been fighting this thing for 3 weeks (off and on of course) and I have finally decided to come to the forum and seek the experts! Any input is greatly appreciated.
This unit comes out of a Samsung Giga-Beat MX-HS8500 home audio system. It's a SMPS made by a Dongquan Solytech Enterprise Corporation (China) and I have the schematics, which would be great if I knew what the hell I'm doing (I am smart enough not to fry the little bit of hair I do have left though). The SMPS board sits adjacent to the main motherboard and they are connected with 24 pin connectors and a male to male wire harness.
I checked the voltages on the SMPS side and there is no voltage present. I started by checking the ST5.3V Stand By power rail and there is no voltage present. From what I have learned so far about these Samsung SMPS is that if the stand by voltage isn't there, then it's most likely the SMPS and not the MICOM chip at fault or its external crystal. Plus, Stand By must be activate for the remote/power button to turn the SMPS on to produce the higher voltages. So, from there I put the main board to the side and I can just focus on the SMPS.
The first thing I did was a visual inspection. I noticed that the bridge rectifiers looked a bit shady on the top side of the board and I did some measurements at the solder joints were the meet PCB. There were some intermittent connections when I apply a little pressure. I touched those up pretty good. This fixed that connection issue. I figured I'd look around a bit more at the solder joints on the entire board. Be anal retentive, I end-up touching up anything that had the vague indication of being cold or "iffy", and that was about 75% of the board. No luck.
Next, I checked all the caps for damage, however it was in-circuit with my MESR-100 ESR meter. The caps all looked in ship shape. I do want to go back and desolder two 1500uF 10V Elecs that are on the 5.3V line just for good measure since they are on the suspect rail. They could be fooling me while in-circuit. After I check the caps, I went to the OPTOs next which I measured with the diode function on my 87V and they look suspect. I changed all but one out because it looked good. I later found the ones I replaced to be good as well (Don't give me the red-ass, I'm still a rookie learning the pitfalls of in-circuit measurements).
I then moved on to the TO-23 mosfets and transistors around the OPTOs and desoldered them and they tested good. I also removed the relays that get the signal to turn on the main power and tested them with one of my bench PSUs and the relays are fine as well as the BAV70 dual switching diodes (DB851, DB852) and the 2N7002BK MOSFET (QQ804). Also all fuses have been checked.
I have yet to check the other mosfets because from what I can tell, they don’t come into play until after I have the ST5.3 Volts Standy By and the 5.3V PS_ON. Next, I decided to check the voltages at the component junctions and there is live voltages on the board. On the schematic below, I have marked some of the voltages that I checked on the cold side.
Any instruction or ideas would be appreciated. This is my first time tackling a SMPS other than a computer PSU, and that has always been a capacitor issue. I only found one reference to this Samsung SMPS and it was a guy on Facebook who said he repaired it by touching up a bulk capacitor that had a shorter leg, so it had wiggled loose. Everything else I’ve found is TV SMPS, and this boards’ layout is like there’s 3 power supplies, because the audio amplifiers have their own section, in addition to the primary and secondary.
P.S. Believe me I have watched a ton of YT videos on Samsung SMPS whether it was a TV, monitor, projects. Also, what is this obscure SQD3011K (I believe this is the special Samsung part number for common a IC they sell that access a) Power IC
It’s a Saken IC, but I haven’t been able to find any datasheet on this part number. I found some similar IC datasheets from Saken (uh… I downloaded them all
) that I believe might be the same but it’s only a guess. STR3A100 Series looks to be the closest thing I can dig up as for as naming conventions that may be similar in denoting the parts characteristics. It’s a hunch.
Big schematic. (Right Click "New Tab") I will upload actual pictures soon.
