I have a failing Samsung SyncMaster 204B. I know that Dave did a repair video on this monitor several years back, where he did swap the capacitors to new ones. And I have actually done that already more than two years ago swapping the old CapXons to Panasonic ones, as the monitor was failing the first time. So now when the picture sometimes seems to be colorless or lacking one color or the monitor is not starting properly, I thought that I would be the big primary side cap, that is now dying. But there was no bulging to be seen on it and after I swapped that one to Nippon Chemicon, the situation got better but not totally fine (the symptoms are a bit rarer now).
So I suspect that the fault is still on the power supply board. So can there be another component that is failing, or should I start to go through the solder joints and connectors, if there's a crack in a joint or bad connection with a connector?
Cheers,
Tuomas
